I am laying a solid oak floor (20mm) onto timber battens affixed to a solid concrete floor downstairs and to wooden joists upstairs.
Downstairs I have run the central heating pipes (lagged) around the edge of the room and the battens have been cut so that they sit on top of the pipes.
In addition to secret nailing, I intend to glue the tongue and grooves (to try and help prevent creaking) and also on the ground floor glue the floor to the battens on the edges of the room where there is not enough wood to nail due to the cut out for the heating pipes - are there any issues/problems with this technique?
Finally, a couple of the rooms are not square (one large room may be a couple of inches out). So that it doesn't show, I intend to try and "lose" the discrepancy by gaining a very small amount on each line of boards on one side of the room (I would insert a thin removable plastic wedge when nailing). This would mean that the boards would not be tight up against each other which I think would be another reason to glue the joints -again, any issues/problems with this approach?
