- Joined
- 28 Apr 2004
- Messages
- 8,381
- Reaction score
- 987
- Country
The flap is open and the braid still has slack on it??Bur w
By being fractionally shorter than the actual span required to open the flap, I should think.
To stop those unruly electrons from floating away?I prefer to remove unused MCBs. And why do people feel the need to keep unused ones “off”![]()
I take it you found nothing else about removing posts either?I did and there were no T&C's saying that helpful and factually correct posts would be removed for no reason.
I don't really see why it would confuse them if it were labelled 'Spare' - or were you perhaps referring to "very simple" people?It clearly confuses people. Very simple really.
Though, IME, there are very many "very simple" peopleI don't really see why it would confuse them if it were labelled 'Spare' - or were you perhaps referring to "very simple" people?
Kind Regards, John
More to the point "What's that braided cable doing that comes out from the inners of the CU"
Maybe, although my comment was really tongue-in-cheek - I don't really think that is what Lectrician meant!Though, IME, there are very many "very simple" people![]()
I agree with you, and so does another manufacturer as they don't fit it on an identical CU.I would agree.
I would also say it is not necessary.
Indeed, which presumably means that you, and that other manufacturer, do not regard the absence of it as representing a 'danger'. Hence ....I agree with you, and so does another manufacturer as they don't fit it on an identical CU.
In view of the rather strange definition that has crept into BS7671, you probably need to be careful about your use of terminology. I presume you mean that if the CU were used without the strap, the fact that it wasn't being used "as designed and supplied" would mean that it was technically non-conformant - since BS7671 now says that a non-conformity is only a non-compliance if it poses a dangerHowever without it, it's not 'as designed and supplied' by Contactum and without it's technically non compliant.
