    Dismiss Notice
Some sort of ventilation
Discussion in 'General DIY' started by Smudge01, 29 Nov 2020.
  1. Smudge01
    Smudge01
    6 Oct 2020
    49
    Thanks Received:
    Country:
    I've just blocked up either end of our car port, and put a doorway in from our garage.
    I now have a room with just a door. I'd like to use this as a workshop, not work in there all day but a few hours here and there.
    I've sorted out the insulation and am now looking at power and lighting, but do you think it is wise to have some sort of extractor in there too?
    If so, what would you recommend. I'm happy to spend a few quid to get it right if needed?
    Any advise would be appreciated.
  2. Bosswhite
    Bosswhite
    15 Jun 2012
    2,821
    Thanks Received:
    391
    Southampton
    Country:
    This has now become a building have you checked Building Regs
  3. Sponsored Links
  4. foxhole
    foxhole
    14 Mar 2006
    17,333
    Thanks Received:
    1,989
    Kent
    Country:
    Whats the construction method?
    • Thanks Thanks x 1
  5. Smudge01
    Smudge01
    6 Oct 2020
    49
    Thanks Received:
    Country:
    Block for the sides, cladding/block/studwork (with insulation) for the 2 ends, pitched roof (with a ceiling (loft above).
  6. Sponsored Links
  7. frutbunn
    frutbunn
    22 Jun 2020
    837
    Thanks Received:
    155
    Country:
    It a material change of use under the B Regs, this means that it is potentially required to comply with quite a long list of regulations, although in reality probably only Part A and B are applicable, possibly Part L if the heating is a permanent fixture.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
