- Joined
- 8 Mar 2010
- Messages
- 341
- Reaction score
- 8
- Country
You are absolutely correct but that is not a very helpful comment.
However, I did install this alarm when I built the house fifteen years ago and it has been working just fine until recently when, I set the RKP and the external sounder started to make the 'noise.' Assuming it was a battery issue, they have both been replaced but still the noise is present when the mains is on. But not when the panel is powered by the battery.
It is either something fundamentally simple or perhaps the panel has developed an electronic fault and needs replacing. Which is easier said than done because it is housed in a kinda 'cubby hole' and the current larger panels will not fit.
