Sourcing 2 gang switched socket
16 Jun 2006
London
Hi all,
I am trying to source the following:
I can find similar ones but none with "silver" rocker switches and the same white inserts.
Can anyone recommend a supplier?
Thanks in advance
Are they Volex? Or Hamilton?
Turn off the juice, loosen the socket from the wall and look on the back. IF you feel competent.
Many thanks securespark
Will order one. I did loosen it when painting around it and took a photo from the back but could only find the quality control sticker. I guess that they were cheapo screwfix ones.
It is only being replaced because one side of the socket doesn't work. (Only the second time I have experienced that).
Is it critical that it matches exactly?
I'm not sure if the new one is an exact match, that's all.
