Spotlights in fitted wardrobe - DANGER?
Up to 3kW of lights can run off a plug.
No reason why that makeup mirror could not be plugged in.
do you think they come with standard plug connections however? as most lights i've seen require wiring in...
The plug is irrelavent.
You can fit one if you want.
What would be the point of having your normal house lighting supplied through a plug?
lol fair point. i only say because i am no electrician and the wardrobe fitter isn't either . so trying to avoid getting an electrician in!
