What is the point of your idiotic meaningless nonsense post?What is the point of this idiotic piece of meaningless nonsense
So to what extent should we be like the plumbers and tell people things which are untrue simply because a proper explanation is too much effort?No. not allowed.
The FCU must protect all of the spur.
I wouldn't point that out, as it is untrue.... hence pointing out that there is never a need for an FCU ...
I obviously might be wrong, but I suspect that he may well have been being confusingly (for the OP, and most other readers) pedantic and attempting to refer to the fact that nothing in the regs (only the guidance in Appendix 15) explicitly says that multiple sockets (or whatever) cannot be supplied by an unfused spur from a ring final circuit. That being the case, it follows that, strictly speaking, a designer can connect whatever he/she likes (including multiple sockets) to an unfused spur if they do so in a manner that would be compliant with all other regulations.I don't know what you meant, then.
If that is a response to the preceding post, whilst I agree that it is unlikely to result in a 'real problem', it represents something that the followers of the guidance in Appendix 15 BS7671 would say 'should not be done' - and (given the 32A OPD), even if one forgets App 15, would only be permissible in terms of of actual regulations if the CCC of the cable to the first socket were at least 26A (i.e. for 2.5mm², only if Method C).I see your point, as long as the design will in the main prevent an over load, then no real problem ...
There's no 'not permitted' about it - you are again referring to the guidance in App 15 - so, as above, provided the (first bit) cable CCC is at least 26A, there is no regulatory problem with two single sockets.So we all know no difference to cable loading with two single sockets or one double, however latter permitted on un-fused spur and the former is not.
One surely can't use that as an excuse for not doing something.Where the problem lies is in the future some one may not test and wrongly assume the unfused spur socket is in fact part of a ring circuit.
I'm certainly not assuming that - but the arguments for it 'not being acceptable' are obviously stronger if/when one or both of the sockets is a double.Are we treating all these sockets as single ones? The diagram shape does not indicate that to me. Is that what I am supposed to have got wrong?
