Hi
Ever since I redone the bathroom and changed it to plastic I've had the issue of sqealing when the taps are either turned off or when the toilet cistern has nearly filled.
Seems like as the supply is stopped then the sqealing comes, has a little whine then stops. It's only effecting upstairs as the kitchen seems ok.
Any idea what this could be? I did consider replacing the main into the house as I thought it could be the stopcock in the kitchen. The plastic pipe also runs from under the kitchen sink to the bathroom without any joins so it has two sweeping curves before any Tees are used.
A little confused here. Any ideas?
