- Joined
- 11 Sep 2007
- Messages
- 951
- Reaction score
- 12
- Country
My main stop cock and water meter are just off the side of the road in the grass verge. The old metal cover kept getting pushed back by the wheels of tractors, so burying the stopcock in mud and breaking the plastic pipe surrounding the meter.
Water board was called and they've just 'fixed' it, but I'm not sure if they've done it right.
The stopcock assembly has been replaced with a new one and new plastic tube to surround it and the meter. There is also a new concrete surround and a new metal cover with a flap. No problems so far, however:
The main problem is that the new metal cover and surround (which stands about 3 inches high) isn't in any way secured to the concrete that it rests on! This means that the whole metal assembly (flap and the metal surround) can easily be lifted or pushed off as it's fairly lightweight. It could easily be knocked off by a tractor (or any vehicle) - to be honest, a very strong wind (which I get around here) could probably blow it off.
Shouldn't this metal assembly be fixed to the concrete that it rests on?
If so, would it cause any problems with the water board if I simply bedded down the metal cover with some cement? Not sure if I trust the water board's contractors to do it right (plus it would probably take them another two months to come back) and it would only take me 5 minutes. Or would this be considered 'tampering'?
Thanks.
Thanks.
