    Dismiss Notice
Stopcock
Discussion in 'Plumbing and Central Heating' started by Johnrossi, 7 Apr 2013.
  1. Johnrossi
    Johnrossi
    7 Apr 2013
    5
    Thanks Received:
    Fife
    Country:
    I need to replace a 3/4" stopcock, but can only find 22mm...will this fit as a straight swap, or do i need extra parts?
  2. PlumbGas
    PlumbGas
    26 Feb 2011
    398
    Thanks Received:
    57
    Surrey
    Country:
  3. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Assuming the OP means a 3/4" thread and not 3/4" imperial copper.
    This needs clarification from the OP.
  4. PlumbGas
    PlumbGas
    26 Feb 2011
    398
    Thanks Received:
    57
    Surrey
    Country:
    I'm making the assumption that the op doesn't know that copper comes in metric and imperial, if it is 3/4" copper then all they need is imperial olives, Simplez
  5. Johnrossi
    Johnrossi
    7 Apr 2013
    5
    Thanks Received:
    Fife
    Country:
    Thanks for your replies...
    Charnwood
    Unfortunately, I am no plumber...the 3/4" is stamped on the side of the stopcock, therefore I presumed that it is a 3/4" stopcock that I need. Not sure if this helps.
  6. SimonH2
    SimonH2
    4 Nov 2010
    5,232
    Thanks Received:
    533
    Cumbria
    Country:
    Photo ?
    That way there's no confusion as to what it may be.
  7. Johnrossi
    Johnrossi
    7 Apr 2013
    5
    Thanks Received:
    Fife
    Country:
    Briefly attached a photo of my stopcock... The number on one side is
    1010-2-6833, on the other side of the stopcock, all it has is 3/4" with the arrow showing flow direction. This is where I have deducted that I need a 3/4" stopcock.
    [/img]
  8. Johnrossi
    Johnrossi
    7 Apr 2013
    5
    Thanks Received:
    Fife
    Country:
  9. JimCrow
    JimCrow
    31 Jan 2011
    411
    Thanks Received:
    104
    St. Kilda
    Country:
    Why do you think you need to replace it?
  10. Johnrossi
    Johnrossi
    7 Apr 2013
    5
    Thanks Received:
    Fife
    Country:
    i had to close the water supply as i was replacing my bathroom handbasin, when I opened the tap once i was finished there is no flow into my tank and therefore no cold water to my cistern and taps. I have no cold water supply...
  11. JimCrow
    JimCrow
    31 Jan 2011
    411
    Thanks Received:
    104
    St. Kilda
    Country:
    crack open the top compression nut on the stopcock, if you get water the ballcock's choked.
  12. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    It is a compression stop tap. Do you have any idea when it would have been fitted?
  13. Agile
    Agile
    26 Jun 2004
    63,561
    Thanks Received:
    4,510
    London
    Country:
    You could use a 22 mm stopcock but fitted with 3/4" olives.
    Or, and and rather better, use a short length of 22 mm tube either side of the stopcock and solder that to the 3/4" tube with 22mm to 3/4" couplers
    Tony
  14. PlumbGas
    PlumbGas
    26 Feb 2011
    398
    Thanks Received:
    57
    Surrey
    Country:
    If you read the OP's posts it clearly says and i quote I am not a plumber, so i think this may be out of their remit Tony
  15. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    5,721
    Thanks Received:
    1,184
    Northamptonshire
    Country:
    Provided the olives are not crushed and the current stopcock doesnt have an odd thread size, then a 22mm stop cock should be a straight swap using existing nuts and olives?
Loading...
Share This Page
