Hello everyone.
I've got an FDC 5kw ti multifuel stove which was fitted in the summer of last year to my existing chimney (apparently liner not required) and have been well and truly chuffed with it so far.
When it was first used it would kick out heat like mad, getting the room so hot I'd have to turn it down through the risk of melting my face off!
In about October / November I had the chimney swept by a pro and he said all was good but I should stop burning house coal in the stove because it produces a lot of soot, although the amount swept was 'reasonable' and apparently 'good quality soot' this advice I have since followed.
Since then I have burned just seasoned wood and some offcuts of timber from work (untreated) all measured to be around 20% or less moisture, except at the weekend when I also use some smokeless coal.
It gets lit most evenings and Saturdays starts earlier
Over the last month the stove seems to be underperforming, getting the room warm, but not scorching (OK it has been a bit chilly recently but after 4 hours of burning the temperature raised by about 5-6c whereas it used to be about 15c hotter than when I started)
Last night I lit it up again and it pretty much wouldn't burn anything, good seasoned hardwood just sat there smouldering and even nice dry offcuts failed to flame more than youd expect from a zippo.
My first thought was air supply, so I opened a window to provide some clean air, this didn't help, I played around with the vents (even though I'm pretty happy with how they usually work) and this didn't do much either, opening the primary air on the bottom gave a bit more flame but nothing substantial, so this evening I decided to give the chimney a sweep and this is what I produced:
View media item 89813
There was some more which I vacuumed up and a little more which ended up in the carpet despite my best efforts (must buy a Vax) is this amount of soot normal???
Its all very fluffy black, almost like talc, but a whole bucket full after a couple of months doesn't seem right to me, of course it could be that my pro sweep a few months ago didn't do a very good job (it only took him about 15 mins which does seem quick, I spent about an hour and a half sweeping all that out)
And could this be the cause of my poor stove performance?
Your thoughts would be much appreciated
