Stripping wood ceiling beams :(
18 May 2017
HI ,
I don't know what my beams are made of , please see attached, but they are covered in what I assume to be woodstain.
I've had two quotes to remove it via blasting , one at £1300 and one at £1500. They both said it was a one day job. I cant afford either !
The surfaces are rough. riven so I cant scrape it off, and advice please ?
thanks
to remove the woodstain so the natural wood finish is exposed - or at least make it an awful lot lighter
I appreciate that the price sounds like (is) a lot for one day but you probably won't be able to diy to it unless you want to spend some time learning how to apply faux wood grain- in short, you apply a light base colour and then use graining rockers to apply a slightly darker colour.
There might be a reason why they were stained darker.
Sorry. I am a decorator but seldom work in houses like your yours.
HI ,
thanks
Do you know when the house was built and if the beams are original?
Blasting is a destructive, expensive, measure to strip back old wood.
Far better to use a chemical stripper and a tin of elbow grease.
You could lightly sand away a small corner to see how deep the stain goes.
150 years old and yes they are original. I just dont understand how you get woodstain out of a deeply riven surface with a scraper or sandpaper.
Depends on type of stain. If it's water based you could try dipping a rag in bleach and rub it in and leaving for a few hours. Wear gloves and protective eyewear. Do a small test pice first. Altrenatively paint stripper following the same safety precautions
Yeah , I did try 15% swimming pool bleach, didnt really touch it to be honest.
I know, right: keep it simple, is another way to look at it.
You can either sand away the deep grooves to remove the stain - killing the character of those vintage beams in the process - or find the right tool for the job of scraping out the stain which might achieve the desired affect but leave additional marks in the bare wood.
What would you do with the bare wood should you manage to remove the stain?
Catch 22 untill you find out how far the stain has penitrated. Best results i have seen is sand blasting, but it aint cheap & very messy.
