Have removed the back fill and lime throat from a potentially original ground floor 1910 cast iron fireplace.
Also started removing parts of the rear hearth that were loose or easily broken off by hand.
There's a strange low density material that makes up the rear hearth, seems almost crystalline and porous - any ideas what it is?
A bit of research has lead me to be concerned that it might be old school Vermiculite and therefore may contain asbestos, can anyone shed any light on my concerns?
Here's an image of the rear hearth from above, you can see the rear wall at the top of the image and the tiled superficial hearth at the bottom.
Here is a lump of the material that I am unsure about, it's possible to snap portions of it with your hands.
Many thanks for your help,
Chris
Chris
