- Joined
- 7 Oct 2018
- Messages
- 25
- Reaction score
- 0
- Country
Hi all....a newbie on here but I've read loads of threads that have helped or gave valuable information over the years.
We're building a detached flat roof garage under permitted development and as it's within 2m of the boundary, it can't exceed 2.5m in height.
The dimensions are 4.5m wide and 5.2m long with the garage door at one of the 4.5m ends. What we're struggling with is trying to get the roof height dimensions as compact as possible to give us as much headroom and garage door height as we can.
What I mean by that is if we allow 25mm ply and EPDM, 150mm firring (to allow a 1 in 40 fall from front of garage to rear) and 225x47 joists (necessary to cover a 5.2m span), we're calculating a wall height of 2100mm. I'm reading that generally, garage doors require 300mm+ of headroom for the mechanism etc. so we're down to 1.8m high garage door......which seems low to me.
Anyone else dealt with this type of scenario? Any solutions to try and create a taller wall height?
We were thinking of installing a 152 rsj across the width in the middle thereby cutting the length of joists in half so we wouldn't need 225mm joists but could use 145x47 joists thereby shaving 80mm off the height. Might need help to calculate if this is OK? Instead of adding firrings to the flat roof, I suppose we could set the wall at the garage door end higher and have the roof run down to the rear. That would raise the front wall above the garage door by 150mm giving more room for the mechanism. Any advice would be appreciated...
