- Joined
- 24 May 2016
- Messages
- 3,984
- Reaction score
- 791
- Country
64 plate car with 60k miles. Bushes on cables all ok, lever stuck in 5th. Clutch working and friend suggested clutch release bearing, does this make sense?
I`ve said the year. Vauxhall Mokka.What car and what year is it?
Not really. You should be able to get it in and out of gear not using the clutch as long as the engine isn’t running. What happens to the lever if you disconnect the cables at the gearbox end?64 plate car with 60k miles. Bushes on cables all ok, lever stuck in 5th. Clutch working and friend suggested clutch release bearing, does this make sense?
It moved around.Not really. You should be able to get it in and out of gear not using the clutch as long as the engine isn’t running. What happens to the lever if you disconnect the cables at the gearbox end?
I remember doing them too, they were a piece of cake to do. They are still in use on the Vivaro so, I imagine just about everything else still has them.Years ago during my apprenticeship at Vauxhall, it was common for the roll pin in Vauxhall selector forks to shear off, leaving them stuck in gear. Maybe nothing has changed?
Yep. Drop the bottom of the gearbox, 1/8” punch, knock the three pieces out and fit a new pin. Before I started my apprenticeship my dad bought a 3.3 Ventora that was stuck in gear. We fitted a recon box - I remember it cost £37.50 but it was still a cheap car. Two weeks later I started my apprenticeship and it was one of the first jobs I helped out on! Grrr.I remember doing them too, they were a piece of cake to do. They are still in use on the Vivaro so, I imagine just about everything else still has them.
The Victor/Cresta/Ventora boxes were lovely to work on. First of all, remove the box leaving the bellhousing in place. Take off the cover on the bottom of the box and there was the laygear! Knock the layshaft out and lift out the laygear to get a good view of the mainshaft, synchro hubs and selector forks. Compare that to other manufacturers!Years ago during my apprenticeship at Vauxhall, it was common for the roll pin in Vauxhall selector forks to shear off, leaving them stuck in gear. Maybe nothing has changed?
And make sure you get all the needle rollers.lift out the laygear
They weren't so lovely when you had to lift half a ton of cylinder head off.A loverly engine
