- Joined
- 22 Jan 2007
- Messages
- 8,525
- Reaction score
- 4,535
- Country
Just wanting to run a few things by you to check I've got this right in my head with what is allowed and what is not.
Some heat pumps need Type-B RCD protection, If you have a full or nearly full CU and can't fit it in, or can't get appropriate breakers of the same make you would need a sub board (or full CU replacement with bigger board)
If you split the meter tails to feed 2 boards.
A. Is there not an issue with both boards having say 100A cutouts, meaning you could draw more than the DNO fuse cutout? (obv they should be doing MD calculation to ensure thats not an issue with whats installed in the house, but are you allowed to split incoming supply to 2 boards in this manner?)
If you did split supply into two boards, would they both have to be the same make? Or could one be Hager and another Crabtree for example?
When I'm checking heat pump installs, I often see CUs with mixed branding MCBs/RCDs in them which I know Is not allowed. But unsure when using sub boards if they both have to be same make, or they can be different.
I know (Think I know) If you have main CU, then had say a 40A fuse feeding a 2nd board, which had its own fuses/rcds for feeding heat pump/controls etc then they could be differnt without a problem?
