D
dextrous
This is more of a curiousity than anything, since I am highly unlikely to do cable installations. However, if you can be bothered...
I keep coming across the need for specialist equipment being used when electricians use SWA cable. Apart from a ratchet cutter, what do you use to cut through the steels neatly when you prepare your cable? Is there a specialist tool or do you just use wire cutters/hacksaw. Like I say, idle curiousity.
