- Joined
- 19 Nov 2020
- Messages
- 2
- Reaction score
- 0
- Country
Just moved into a new rented flat in Zurich and as is common most of the light fittings have been removed (?!) [previous renter was British] I bought a contactless tester, to check out wiring. We've since had a local sparks check things and fit some new lights, but I was surprised by what I found:
1: Cooker is controlled by 2 MCBs in the flats consumer unit (turns out it's 400v across 2 phases)
2: There is NO off switch for flat as a whole. Flipping all the MCB + 1 MCBO still leaves the lights live
3: With only one light fitting installed (left behind) ALL the (dangling out of the ceiling) wire-groups show as "live" (contactless only, so I guess 1 wire is live in each) regardless of the setting of the wall light switches.
a: It looks like the light switches cut the Neutral feed, live (to lights) is permanent/unswitched?
b: I suspect instead of just live and neutral (+earth) colours, the Swiss colour each live phase differently? So 3 live colours, 1 neutral + 1 earth colours.
c: The kitchen power has RCD protection (via that single MCBO) but the bathroom is unprotected, with a 10A 230V supply.
d: The sparks wired the new lights with the circuit live (as I said no way to switch) as he joined cables , lights in the flat came on.
