Just want to put this to you.
I have a ring main in the kitchen RCD protected 32 MCB. On the ring i am putting an unswitched 13 AMP socket in a cupboard where i will plug in a transformer that will supply my outside lights. It is the B&Q range. click the link for a picture.http://www.diy.com/diy/jsp/images/product/largeImage/5011274795320_H_1_x.jpg
So that is what is happening below the work surface, but obviously i need to operate it from above the work surface. I have pulled a wire from the unswitched plug, well i guess this could be unswitched or switched it doesn't matter and this wire is in a single back box above the worksurface. the wire is 2.5mm T&E as is the rest of the kitchen ring main.
Can you please advise what switch i need (i.e switched fused) 20amp, 40amp DP as i have lost the plot on this one.
