Switching Unused Sockets Off: Settle The Argument!
7 Jan 2014
West Glamorgan
Wifey is a PITA for doing this, citing 'they', as in, 'they say you should...' Who says so, and why? Apart from the little red light on some sockets (and the danger of kiddies poking their fingers in them), is there a power usage if you leave them on when no appliance is attached to them? Thanks.
CG
Well TVs certainly use a bit of power in standby.
And if the washing machine is only used once a week, may as well turn it off.
I guess the only benefit of that is that when you plug something in, it will already be turned off so your not plugging it in under load.
There was a time when wall socket did not have switches. Imagine all that wasted power!!!
And any way, turning it off at the switch just makes the electric leak out the innards of the switch rather than the socket, right?
Nozzle
any modern item on standby must be no more than 1w
a socket red light may consume perhaps. .01w max or .1w every 10 hours or .25w per day or 90w a year a massive 1-1.2p a year so every 9 sockets 10p a year :D
could be a bit less or a bit more but pence a year
any modern item on standby must be no more than 1w ... a socket red light may consume perhaps. .01w max or .1w every 10 hours or .25w per day or 90w a year ...
Your argument might be even stronger if you got your units right.
In terms of the figures, one issue is obviously that not all items are 'modern' - I certainly have a good few that consume very much more than 1 W on standby.
Kind Regards, John
