Tank to supply bath.
28 Jul 2010
Bristol
Hi. To date we have used Galaxy under counter heaters to supply all our hot water needs and they're excellent. Hot water when you need it short dead runs etc.
We now want a bath and a Galaxy isn't up to filling a bath. We only have an electric connection but we do have two multi-fuel stoves (coal/wood).
Ideally I would like a tank which can take a 240v and 12v (from a PV) heating element plus indirect heating from the stoves. I appreciate that a stove is an uncontrolled heat source and I would need to design as such. Are there multi source tanks out there? Any recommendations from those who have already done this?
We're pretty much off grid i.e. £10 month electricity and really would like to use the stoves to heat/pre heat the water.
Cheers.
how many litres per minute of cold water from the mains come out of your kitchen cold tap?
do you already have a hot water cylinder?
do you already have a cold water tank in the loft?
have you got room for either or both?
Cold water taps are mains pressure restricted so the water doesn't splash up from the sink bottom. No cylinder or tank. Loft does probably have room for a tank. Maybe 5 foot to apex as the ridge is only 18 foot high. I was thinking tank in loft and cylinder in garage loft. Head would only be 2 foot between cylinder and bath but could use 12v impeller.
to fill a bath you need a good flow of water. See if you can measure the litres per minute available from the mains by timing a bucket to full at a garden tap or some other outlet such as a washing machine hose.
It is very important to know this figure in order to decide what sort of system would be suitable.
Flow is not the same as pressure.
It is preferable to have your hot water storage very close the the batgroom and kitchen taps, but also fairly close to (and above, or gravity) the boiler.
