Pedant
All the OP needs to know is that there should be a potential difference of 48v between the A and B legs.
Good heavens do you really think that the guys who jumper these things in the cab bother very much about which colour goes where?Shouldn't that be +48 volt ?
The exchange battery positive is grounded at the exchange. At the exchange the A wire is connected indirectly to the battery postive and the B wire is connected indirectly to the battery negative
The A wire is positive relative to the B wire
The Orange is normally the B wire
http://www.wppltd.demon.co.uk/WPP/Wiring/UK_telephone/uk_telephone.html
Indeed polarity can be relevant but even for SS lines the polarity correction would be applied anywhere on the system. As a youngster our phone was supplied by an open wire pole route and when this was changed to UG feed to the DP us and the neighbours had the wrong service, the engineer came indoors and swapped the wires over, I tried to convince him the problem was elsewhere as no one had been in prior to him.Yes, 48v in the US, 50v in the UK (nominal). Memory slipping now, its 50 years since I was a telephone apprentice....
In my day it was very important that A&B were the correct way round, as reversal on some legacy system (eg shared service) could provide some interesting results!
Thinking of how/when it all started, given the voltage drops in those very long and tiny conductors when an electro-mechanical bell rang, I would imagine that a 'couple of volts between friends' one way or the other would be of very little consequence!Thanks, yes, my mistake. Edited now.
Actually it's 50.5V
It would as long as currents are very small.Thinking of how/when it all started, given the voltage drops in those very long and tiny conductors when an electro-mechanical bell rang, I would imagine that a 'couple of volts between friends' one way or the other would be of very little consequence!
Well, I'm even less worried about "a difference in polarity between friends"Yeah, but I was 96 volts off!!![]()
