- Joined
- 7 Sep 2022
- Messages
- 4,931
- Reaction score
- 1,438
- Country
I'm still not sure why you'd want to remove the screed?40mm screed
Not in a "force along the grain" direction. Along the grain, a block of wood is a postthink a block of wood is much weaker than a post
It's something of a nonsense to assert that a wooden support is incapable of adequately supporting a wooden staircase because the support is made of wood
I do wonder about what you think some times, but oftentimes it seems to be a healthy wedge of unlikely whatabouteryI don't think adding a block is quite the same
Sounds like you're asserting that a staircase arrives from factory perfectly square and if installed such that it will drop by 2mm when installed, it will squeak when walked on forever. It will just twist the 2mm, come to rest and function as you expect. Wood doesn't shrink at anything like the rate you purportA couple of mm of sinkage could mean a lifetime of squawking!
Yes they do tend to float away if you don't bolt them down, don't they?hold it down as well as up
It's why I say stairs aren't to be trusted; they're always up to something
