I have a Texecom 412 with v10.4 and ComIP.
I setup the ComIP and can ping it, AND connect to it using Wintex over my LAN.
Additionally, I port-forwarded ports on my router so I can also see the ComIP over the Internet.
To test, I reset my UDL to 1234. I configure Wintex with UDL of 1234 over IP and it works 100%
However, I've installed the Texecom App from the App Store (iPhone) and set it up. Whether it uses local LAN IP or my Internet IP I get the same problem, I try to open the Panel or the Smartkey and it says:
"Requesting Access.."
"Logging into Panel..."
"UDL Password Does Not Match!"
And does not connect. I've double checked and the UDL is set to 1234 on the App. The same one Wintex is working 100% with.
Any ideas what could be causing this?
Thanks.
Thanks.
