Texecom adding internet access to use app
27 Sep 2020
Hi - just reading posts on DIYnot out of curiosity looking at Alarm section though I have a post on tiling hence on this site today.
I have a Texecom premiere elite 24W Ricochet year 2013 Version 2.04.
I was curious on a post that sounded like a private individual signing up for a cloud account with Texecom......I was not aware this was possible.
I have thought for a while it would be nice to connect my panel to the internet thinking I can turn the alarm on or off via the app and even maybe be informed of any reason for an alarm condition? I belive the app is Texecom Connect?
I think my system needs a firmware update to do this too.
I have Wintex V8.2 (recently upgraded to this following PIR replacement so that Wintex/Ricochet Monitor understood what the item was.).
I installed the system and programmed it myself. (I am a retired Electrical Engineer though I did need some help from Texecom to get the panel to trigger an external GSM dialler when the alarm is triggered). I appreciate the skills of people like yourself as these alarm systems are complicated.
I'm happy to buy the software/cable as required to update the firmware but I have a question or 2.
Do I need to factory reset the panel before updating the firmware?
Once updated can I simply download the program file using Wintex or do I need to start from scratch or do something else?
I'm only interested in doing this if I can use the app/cloud services to turn off the alarm if activated and to see what the issue is.
I have a Ricochet smart key I leave with neighbours to turn the alarm off if it is triggered but it would be nice to have remote access.
The alarm has only been triggered 3x or so since install. Twice for faulty PIR's, one ricochet the other wired. The third was due to an extended power cut that killed the panel battery I believe. All batteries have been replaced (I do it about every 5 years) though recently I also replaced the bell box's completely.
Any advice or reply is appreciated.
Kind Regards
Looking at Secureiam web site I see there are 2 options to connect to the internet.
Texecom SmartCom Wifi / LAN CEL-0001
Texecom SmartCom Pro Wifi / LAN CEN-0001
I need to google more but which wouild be best for my needs?
Can I create an accout with Texecom cloud before I get my alarm panel connected to the internet?
Delete wireless devices via zone setup
Default panel
Flash firmware
Default panel
Re learn devices
Re program panel
Add smartcom
Set up cloud account
Add panel to cloud
Set up app.
I wouldn’t use Wintex to send data back given the vast change in firmware.
Thanks for that.
I assume I can use wintex version I have to fully program the kit?
Can tyou advise which smartcom I should get.
Thanks again for any advice.
