Texecom Elite 24 v2 to v5 flash upgrade
11 May 2019
i have followed the instruction over and over again and cannot get connected to the board. Any thoughts or suggestions welcome thanks M
Sounds silly but make sure the flasher lead is in the correct way
Can it put in the wrong way ,,, the 10 pin one could I suppose ... the others can’t is that wants u mean
Just seen your image I cannot believe I have been that stupid I’ll try that in the morning and let you know
Confused that diagram shows it going down with the line on the left that’s how I have tried but the image from the otherngillyd suggest the other way
#texecom instructions need to be more clearer lol
Right the flash worked I have the right v5 on elite 24.
Issue I have now is the following 3 messages
Areas Needs Reset AB
ATS PATH Fault
COM2 Fault
I have all my settings saved on winter but cannot connect to panel via the com ip , for reference the com IP is on COM2 and COM1 is GSM.
Any help would be much appreciated
Did you default the panel after upgrade ?
I personally would print out your old version 2 config , then make new one on wintex as a version 5 panel as you may find some strange things if you edit the account and load it in
Remove Gsm from com 1 set as not used then connect via lead to wintex on pc
Check UDL code as it will have defaulted to 1234
Now that’s done have you put the Gsm com back on , then go to com port set up on keypad and set to com Gsm, it may take a couple of mins for the Gsm to come back live
The gsm is live but it gives no ats available what does that mean ..
One of 3 things
Com 1 no Gsm
Com 2 no internet
Com 3 ( onboard digi ) normally com 300/ 2400 no phone line ...what does it say in onboard digi ?
