Hi all,
I have brought a Telxeom Elite 64W kit with wireless keypad, wireless bell and 3 wireless PIR's.
I'm having an issue setting it up.
I have no wired equipment, just what comes with the kit.
Before I powered it up I used the supplied cable to connect the back of the keypad to the engineer port as I believe this is needed to learn the first wireless keypad.
So I powered up - it went into an Alarm, I put the batteries into the keypad and used the engineer code to stop the alarm. I go into engineer mode, it asks to set language, then once language is set it asks to 'confirm devices'. This is where I think I'm having a problem, I see:
Net RKP> ........
1 Exp> ........
I select Yes, then Yes to confirm but nothing happens (manual says it should go to "Learn Richochet" at this point.)
If I manually go to the 'Learn Ricochet' menu option it just says "All Devices Learnt"
I'm assuming the panel isn't seeing the panels onboard Ricochet receiver.
This is as far as I can get and can't actually learn any of the wireless devices.
Am I missing something? Do I have to enable the onboard Richochet receiver somewhere first?
Thanks for any help with this.
Net RKP> ........
1 Exp> ........
