Hello guys,
I have problem with installing Com2400 on Elite 64 Texecom panel. Panel is configured as it should according to the manual and Com2400 is set as an onboard modem, but the panel says ATS fault, ATS not available and would not generate any events or even make a dial attempt.
I found 2 different instructions on wiring, one shows that both 10pin connector and com1 lead are connected, the other shows only the 10pin. What is the logic in them both being connected, is it for UDL usage? or that is the problem?
I read in the forum that the voltage between R and T should be 50V, but I have 30V, this is unofficial information and is not from a manual so I don't want to risk damaging the board, but could that be the real issue?
I am out of ideas and would appreciate your help!
