- Joined
- 14 Feb 2025
- Messages
- 3
- Reaction score
- 0
- Country
Hi all, first post here! I've got an texecom premier elite 24 existing setup with a smartcom on com ports 1 and 2. I also have a ComPort+ model A5147-02-01 connected to the Digi Modem on the main board (currently used just as a backup if connecting over usb). I want to add homebridge capability (while still using smartcom) using the homebridge-texecom plugin and using a direct serial connection to my ubuntu server via a ttl to usb serial converter (with FTDI FT232RL chip which I think should work). I have wired up the pins as per diagrams on this forum for GND, TX, and RX. However, when I go to program the elite 24 and tell it to use crestron over the digi port there is no crestron option (as previously mentioned in other forum posts). There are options for COMIP, some gsm modules etc. Does anyone know if its possible to have the COMIP for the smartcom on the digicom so I can use the crestron protocol on com 2 or com 1. I recall trying to set it up this way previously and not being able to but I set the system up around 3-4 years ago now. Thanks in advance for any help!
