Hi all,
Just after a bit of help, I have tried to flash my Premier Elite 24 panel to the latest v4.03 firmware and fear the panel is bricked. It was on the original firmware from when I installed it some 3 years ago so was on V2.xx (don't know exactly). The reason for updating was to upgrade to the Connect Smartcom. Anyhow, I followed the instructions to the letter, saved all my panel data to Wintex then proceeded to flash. All seemed to be going well, I pressed reset on the flasher and the power went off on the board which I assume is normal? It started the flash and got to the stage "erasing chip" but then I got an error message saying the panel had failed to respond, or something like that. After this the panel is dead, no matter what I do I cannot power it up. There is power there, 13.7 v but nothing is happening. Tried loading defaults by disconnecting the mains and battery, then connecting battery, holding load defaults and applying mains but not a thing. On my keypad it displays v10.100 ADD=100 W=0,0 and then a series of symbols ...which doesn't look a good sign
Just wondering if there is anything I can try to bring it back from the dead? Or am I buying a new panel and calling in the pros?
Any help/advice greatly appreciated (you can point and laugh too, I don't mind
Andy
Andy
