Texecom Premier Elite Night arm settings
18 Aug 2011
Hi guys,
Recently fitted a Premier Elite with smartcom
Have a question regarding the part arm 1 (night arm) setting
I have all my pirs and door contacts in Area A and have ommited the relevant zones for part 1
The front door contact is set to Entry/Exit 1 and full alarm is set to timed mode.
When using part arm and system is armed opening the front door contact sets off a entry timer instead of a immediate alarm which setting would i need to change to set this?
Also is it possible to only need to press the part mode on the keypad to initiate arm sequence?
as for part arm, with quick arm turned on it be part then tick/yes, as there are 3 part sets per area, you would have to select the correct part set then press tick.
if area arm suites, the its part twice, select the part set then yes/tick
