Hi all,
After acknowledging an alarm or disarming the system, the panel emits many "Tick" sounds from Keypads.
"Tick" sound disappears after entering the Engineer code on the 2 Keypads.
Without seeing hearing it can’t comment much more.
i am aware of the keypads may do a clicking sound and usually applies to power or interference and isn’t permanent, but it does suggest something isn’t right.
I will disable one of the two keypads to rule out any possibility of a problem.
I should mention that the clicking noise is recent (after installing a wired 8xp) and only occurs after an alarm is acknowledged and the system is disarmed.
After connecting the engineer code on both keypads, the clicking noise disappears.
as adding the 8XP is when things started I would measure voltage getting to the keypad and the expander.
I would disconnect the expander power and T and R and see if that resolves the problem and measure the voltage at the two keypad
this will give an idea if its power related, or interference, it should also highlight if the expander is causing the problem and it can be looked into in more detail.
cant see power being a being issue with one pir and one smoke, the network has 1 Amp to play with, 300mA for the keypads and the expander and at a push around 100mA for the two devices, but to be certain you can look up consumption in alarm
well its clear as suspected it isn't power supplied being the issue.
without hearing the tick its hard to say.
You can make the keypads tick by changing the tones of the keys when pressed.
If you press Yes and Menu together then press yes until you get to Keypress sounds, does it say click, the default setting is beep. this is a keypad function and its specific to the the keypad you are on.
I would check that your network wiring is clean and tight at panel end, expander end and at both keypads.
