As part of an accommodation "deal" I've just had a brand new 172 litre thermal store purchased and fitted by a mate in the cellar to replace my 12Kw on demand Redring Powerstream.
I have it running as a Direct (electric) thermal store using 2x 3Kw elements, both set to 70 degrees. I have 100mm of insulation on the tank. I let it heat up overnight and today on both elements.
Ran a bath this afternoon and as I swished my hand though the water was expecting HOT water instead had warm water. I ran downstairs and grabbed the room thermometer and my bath was 38 degrees - a luke warm bath!
Doing some investigation I made sure the blending valve was on the hottest it could go - removing the cap off it and twisting it to max. About 15 litres comes out nice as hot as expected but then soon cools down to a moderate 35-40 degrees, enough for a cool shower or bath.
Still to find out if its the blender valve or the thermal store is at fault. At this rate (taking into account standing heat loss rated at about 2Kw a day) I would get comparable performance (but not the flow) from my 12Kw Redring Power Stream. And for a single person, the thermal store would be more expensive to run.
Perhaps there is a fault somewhere or is the water running though too fast to be heated by the heat exchanger.
Annoying thing is I have paid out over £200 for parts and labour to get it installed on recommendation by a mate only to get 15 litres of hot water then luke warm water.
