gas4you wrote
I think you mean acheiving boiler condensing for a percentage of the boiler run time during the re-heat.
DPS's states their small 125 liter UV cylinder which uses a plate hex for the re-heat produces 100/L more hot water over a one hour period than a 300L UV cylinder reheated using a coil.
Its due to the efficiency of the plate during re heat and the fact that the heated water is pumped directly into the top of the cylinder where its needed unlike a coil which is at the bottom and relying on slower convection currents.
Thats how DPS describe it anyway. I ve seen a few plumbers install systems this way. Their not the usual "run of mill" type of plumber (no offence to anyone) IMO. The re-heat times are what impresses them and the ability to match the heat exchanger exactly with the boiler output.
Which is more efficient.? The super fast re-heat with less condensing (subject to store temp)taking place with the small volume of water or the slower reheat with more condensing taking place with the large volume of water. ?
but the basic physics just doesn't add up.
