Hi all, hope someone can help please.
I have recently replaced an ageing mechanical thermostat with a new but inexpensive Drayton “CombiStat” (1). It works ok but my heating switches on an off much too regularly - on/off approximately every two minutes which is clearly very inefficient and pretty noisy at 7am too.
I was advised to try a digital thermostat as they apparently switch more intelligently and as a result are much more efficient, so bought a Floureon (2) (https://www.amazon.co.uk/dp/B0752F87K8/ref=cm_sw_r_cp_tai_WhQrAbKV5SE7Q). I installed the Floureon attempting to follow the Chenglish instructions and managed to get it up and running, display working correctly, etc., but it didn’t actually fire the boiler up when the require temperature was set much higher than the current room temperature.
I am wondering if the old timer I currently have installed needs to be set in a particular way or even bypassed altogether - it also controls my hot water - I tried it set in all possible states, but to no avail.
I’ve included photos of the current mechanical thermostat and the current installed water/heating timer.
Many thanks in advance.
