thought this was rather good
16 Mar 2004
Dear Technical Support,
18 months ago, I upgraded to Girlfriend 1.0 from DrinkingMates 4.2, which I had used for years without any trouble. However, there are apparently conflicts between these two products and the only solution was to try and run Girlfriend 1.0 with the sound turned off.
To make matters worse, Girlfriend 1.0 is incompatible with several other applications, such as LadsNightOut 3.1, Football 4.5, and Playboy 6.9.
Successive versions of GirlFriend proved no better. I tried a shareware program, Slapper 2.1, but it had many bugs and left a virus in my system, forcing me to shut down completely for several weeks. Eventually, I tried to run GirlFriend 1.2 and Girlfriend 1.0 at the same time, only to discover that when these two systems detected each other and they caused severe damage to my hardware.
I eventually upgraded to Fiancée 1.0, only to discover that this product soon had to be upgraded further to Wife 1.0.
While Wife 1.0 tends to use up all my available resources, it does come bundled with FreeSexPlus and Cleanhouse2003. Shortly after this upgrade, however, I found that Wife 1.0 could be very unstable and costly to run.
Any mistakes I made were automatically stored in Wife 1.0's memory and could not be deleted. They then resurfaced months later when I had forgotten about them. Wife 1.0 also has an automatic Diary, Explorer and E-mail filter, and can, without warning, launch TurboStrop and Whinge. These latter products have no Help files, and I have to try to guess what the problem is.
Additional problems are that Wife 1.0 needs updating regularly, requiring ShoeShop Browser for new attachments and Hairstyle Express which needs to be reinstalled every other week. Wife 1.0 also spawns unwelcome child processes that drain my resources. These conflicted with some of the new games I wanted to try out, warning me that they are an illegal operation.
Also, when Wife 1.0 attaches itself to my Audi TT hard drive, it often crashes.
Wife 1.0 also comes with an irritating pop-up called Mother-In-Law, which can't be turned off.
Recently I've been tempted to install Mistress 2004, but there could be problems. A friend of mine has alerted me to the fact that if Wife 1.0 detects Mistress 2004; it tends to delete all of your Money before uninstalling itself.
Please help?
More .... ;)
Dear Technical Support:
Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed that the new program began making unexpected changes to the accounting software; severely limiting access to wardrobe, flower and jewelry applications that operated flawlessly under Boyfriend 5.0.
No mention of this phenomenon was included in the product brochure. In addition, Husband 1.0 uninstalls many other valuable programs such as DinnerDancing 7.5, CruiseShip 2.3, and OperaNight 6.1 and installs new, undesirable programs such as PokerNight 1.3, Football 5.0, Golf 2.4 and MassiveClutter 4.5.
Conversation 8.0 no longer runs, and invariably crashes the system. Under no circumstances will it run DiaperChanging 14.1 or HouseCleaning 2.6. I've tried running the Nagging 5.3 fix but this all purpose utility is of limited effectiveness.
Can you help, please!!!! Jane Doe
Dear Jane:
This is a very common problem women complain about, but it is mostly due to a primary misconception. Many people upgrade from Boyfriend 5.0 to Husband 1.0 with no idea that Boyfriend 5.0 is merely an ENTERTAINMENT package. However, Husband 1.0 is an OPERATING SYSTEM and Was designed by its creator to run as few applications as possible. Further, you cannot purge Husband 1.0 and return to Boyfriend 5.0, because Husband 1.0 is not designed to do this.
Hidden operating files within your system would cause Boyfriend 5.0 to emulate Husband 1.0, so nothing is gained. It is impossible to uninstall, delete, or purge The program files from the system, once installed. Any new program files can only be installed once per year, as Husband 1.0 has severely limited memory. Error messages are common, and a normal part of Husband 1.0. In desperation to play some of their "old time" favorite applications, or to get new applications to work, some women have tried to install Boyfriend 6.0, or Husband 2.0.
However, these women end up with more problems Than encountered with Husband 1.0. Look in your manual under "Warnings: Divorce/Child Support". You will notice that this program runs very poorly, and comes bundled with HeartBreak 1.3. I recommend you keep Husband 1.0, and just learn the quirks of this strange and illogical system.
Having Husband 1.0 installed myself, I might Also suggest you read the entire section regarding General Partnership Faults [GPFs]. This is a wonderful feature of Husband 1.0, secretly installed by the parent company as an integral part of the operating system. Husband 1.0 must assume ALL responsibility for ALL faults and problems, regardless of root cause. To activate this great feature, enter the command "C:\ I THOUGHT YOU LOVED ME". Sometimes Tears 6.2 must be run simultaneously while entering the command. Husband 1.0 should then run the applications Apologize 12.3 and Flowers/Chocolates 7.8.
TECH TIP! Avoid excessive use of this feature. Overuse Can create additional and more serious GPFs, and ultimately YOU may have to give a C:\I APOLOGIZE command before the system will return to normal operations. Overuse can also cause Husband 1.0 to default to GrumpySilence 2.5, or worse yet, to Beer 6.0. Beer 6.0 is a very bad program that causes Husband 1.0 to create FatBelly files and Flatulence.wav files and Loudly wave files that are very hard to delete.
Save yourself some trouble by following this tech tip! Just remember! The system will run smoothly, and take the blame for all GPFs, but because of this fine feature it can only intermittently run all the applications Boyfriend 5.0 ran.
Husband 1.0 is a great program, but it does Have limited memory and cannot learn new applications quickly. Consider buying additional software to improve performance. I personally recommend HotFood 3.0, Lingerie 5.3 and Patience 10.1. Used in conjunction, these utilities can really help keep Husband 1.0 running smoothly. After several years of use, Husband 1.0 will become familiar and you will find many valuable embedded features such as FixBrokenThings 2.1, Snuggling 4.2 and BestFriend 7.6.
A final word of caution! Do NOT, under any circumstances, install MotherInLaw 1.0. This is not a supported application, and will cause selective shutdown of the operating system. Husband 1.0 will run only Fishing 9.4 and Hunting 5.2 until MotherInLaw 1.0 is uninstalled.
I hope these notes have helped. Thank you for choosing to install Husband 1.0 and we here at Tech Support wish you the best of luck in coming years. We trust you will learn to fully enjoy this product!
