Hi, after a bit of help guys.
ive got a potterton floor mounted old fashioned, boiler, pumped system with header tank in the roof, and a three port valve. just gone to turn on the heating and nothing has happened. the room stat is fully up and ive heard the click as it passes the temperature, no air lock as ive checked the rads and given them a quick bleed. when i put the water on the boiler kicks in and the system works and the pumps going. looked at the port valve and its permanently on the W setting. if i flick it across using the manual arm it fires up the boiler for the heating and then just shoots staright back across to the w setting. Even if i put it on M it still wont fire up. So in summary i know the boiler works ok so is the 3 port valve stuck?
Quick answers would really be appreciated
Thermo
Thermo
