i've had a good look but can't see nothing. I am building an extension which will have ensuite. I want to tile it. 2 walls will be stud work, could i attach 12mm ply to this and tile direct to the ply? or is there a better way?
whats the cheapest way to do my beeze block walls. its probably going to be dot and dab, then skimmed. Or would it be better to get a one coat plaster on there with a fairly smooth finish and tile direct ontot hta. Or should i just dot and dab and not skim.
thanks for any advise.
