Hello guys,
First time posting so take it easy! I've got a single skin garage on the side of my house, with solid foundations (BC happy with them) and walls seem to be straight and in decent condition generally. Hoping to do a simple timber frame first floor extension above it (timber frame because it's lightweight and can potentially do what I describe below, also relatively easy to build for me). A builder I've been talking to reckons that you can simply sit the 150mm wall plate timbers (for first floor timber frame ext) on top of the existing 100mm blockwork single skin, with the other 50mm supported by vertical timbers on the inside of the single skin - I guess you'd build it like a stud wall underneath the wall plate. Does that sound feasible/possible? I like the idea because I'm keeping it as low-budget as possible and it sounds fairly simple/low-cost, but
I can grab photos if that will help but there's not a lot to see ATM.
thanks
thanks
