TNS OR TNCS
14 Sep 2005
Hello,
When filling out your test cert form. How do you determine between
TN-CS and TN-S earthing arrangements?
Thanks..
Don't mean to be rude but if you can't work this out should you be filling out the form in the first place??
On a more helpful note try looking in your OSG.
If observation doesn't provide you with a definate answer, then try comparing Ze to P-N external loop, if they are the same, then there is a good chance of TN-C-S ,or you could just phone up and ask the suppier, and they will pull one out of a hat for you :lol:
craig. have a look at the suppliers main fuse. If it has PME written on it and the main earth cable goes into the actual cut out on the right then that would normally be TN-C-S. You won't be able to get at the terminal without breaking the seal though.
If you can see that the main earth cable goes to an external connection next to the cut out, or is connected to the cable sheath below the cut out, then that would imply TN-S.
You need to test or enquire to confirm though.
From your previous postings you are using building control? So they, or their agent will sort the paperwork for you I would imagine.
Cheers Harvey.
Good info, I just wondered how you could tell visually as aposed to
breaking the seals. Thanks for explaining.
Mr bjs spark I didnt say I was going to be filling out any forms myself
just interested in how the pros can tell the difference.
Then why not ask your 'pro' when he comes to test and inspect your DIY extension wiring and fill out the forms??? :wink:
Most PME service heads have a sticker saying so.
Their supply cables are skinnier than TNS.
The earth always comes from the cutout, via the PEN conductor.
TNS earth comes via the supply cable sheath.
