And what do you do with it then?Nobody will like this idea; try putting the toilet paper in a wee flip top bin at the side of the toilet like they do in most other countries.
Bin it.And what do you do with it then?
It’s not even getting round the U bend never mind a passage to the works.'Proper' toilet tissue will dissolve in the water during its passage to the Treatment works,
You put poo in your bins in Scotland?Bin it.
Yes, that's what I do. Then I have to flush the toilet yet again to wash the bits of paper off the toilet brush.Stir it up, tissue will soon disintegrate in water.
Other things to check for are slack between the plastic arm on the spindle and the flush valve rising and a worn diaphram on old valves and with some newer duel flush valves you have to hold the handle down for a second or so longer to release a full flush of water.
I’ve got some toilet paper in water now, still waiting for it to dissolve.
The discussion was never about poo, it was only ever about the paper.You put poo in your bins in Scotland?![]()
I think I know the difference between toilet paper and anything else.Are you sure it's toilet paper, all that we get, no particular brand, breaks up in the pan instantly.
If you put used toilet paper in your bin, you are putting poo in the bin!The discussion was never about poo, it was only ever about the paper.
And, Scotland was never mentioned either.
You've just joined my ignore list.If you put used toilet paper in your bin, you are putting poo in the bin!
No I'm not. I was simply quoting your earlier post. You said to put the toilet paper in your bin.You've just joined my ignore list.
Reason; trying to be a smarty pants.
