I suspect this has a simple answer!
All i've read so far has 32A as the lowest rating for the MCB at the consumer unit in a cooker radial circuit.
I'll be installing a cooker with a max current of 16A according to the specs. Is it okay to put a lower rated MCB on the circuit at the CU, or does this contravene some regulation?
Alternatively, should i connect the oven to the controller unit via a FCU with a suitable fuse?
(question reposted from general DIY where it ended up by mistake the first time - just in case anyone's seen this twice!)
