Too many Poles!!
10 Feb 2007
Cumbria
Can someone lay out the need for certain switchgear and their number of poles? Where you find them and their operation.
I have a little bit of confusion over them?
Single pole switch;
Double pole switch;
Triple pole switch;
single pole switch - only switches live (used in lightswitches)
double pole switch - switches live and neutral
three pole switch - used in fan isolators where it is a timer fan, or on a three phase supply. please could some sparkies comfirm this.
hope that helps
Yeah seems good to me.
DP are usually used on anything containing a heating element, and switched FCUs contain a DP switch.
Single phase consumer units usually have a DP main switch.
Three phase CUs usually have a 3 pole switch, but some may have a 4 pole switch if the neutral is also switched.
Although there is no requirement in the regs to switch the neutral in some circumstances...(is there an icon for putting a spanner in the works?) :wink:
