Too much tape?
28 Mar 2011
Conwy
Firstly, if you're going to use PTFE to seal a compression joint in a water supply pipe, is it possible to use too much tape? And by "too much", I don't mean ten or twenty turns, but maybe three or four.
Secondly, is there any benefit to be had in adding a smear of silicon mastic to the thread before putting on the tape? I ask because as an occasional DIY plumber I sometimes have trouble sealing compression joints, and I think I may be doing something wrong. In all cases I clean the pipes, then apply two or three turns of tape to the threads along with a smear of silicon. Sometimes I put one turn of tape on the olive too.
Case in point right now is a particularly stubborn isolating valve which I've fitted in a pipe run to an outside tap, which despite silicon, tape and parts having been well cleaned before assembly is still weeping; and this after being nipped up several times with a spanner to the point where I daren't nip anymore.
Do not use PTFE tape on compression fittings.
A smear of jointing compound if you feel the need (suitable for potable water)
The threads don't form the seal - that's the olive being compressed onto the tube.
Adding tape to the threads achieves nothing and can hinder the fitting being tightened.
I was with an insurance assessor a few months ago and his comment was "When I see tape on joints I know it was a DIY job and reject the claim"
I'll try without tape next time and see what happens. It would be nice to think that I never had to bother with it again, especially when trying to wrap a joint which is already in place and close to a wall.
Equally, jointing compound on the threads would be useless.
However, rolling PTFE tape onto the olive DOES help to make a sound and leak-proof joint. I see no point in putting grease on it.
A smear of jointing compound on the olive is the old school way and that's how I was taught to do it .works fine for me
PTFE I use very rarely preferring loctite 55,can't remember the last time I bought any PTFE either!
Still got a roll of loctite gifted to me by the lanky one!!😆😆
Still have a shed load of the stuff :LOL:
I wonder if they do Which? approved PTFE? :LOL:
Should only be used on a mangled olive or poor quality fitting (which I concede is becoming more common these days).
And this is why you should stay in the general forum with the rest of the doughnuts. :rolleyes:
I still use ptfe (not on olives), I asked for some Loctite 55 in PTS round our way ages ago. They said they used to stock it but not any more cos no one ever bought it. :eek:
Slightly differing opinions, then, though I think there's an agreement that tape on the threads is not a good thing.
Just wondering, Newboy, about the comment by your insurance assessor. Surely he's on sticky ground if he refuses a claim based on the taping of pipe joints which were inherited by the householder or business owner from a previous occupier?
I've never seen a household insurance policy that says "we cover for damage caused by Escape of Water, but not if we think that plumbing repairs and alterations have been carried out to a poor standard, unless we think the poor work was done by a plumber, in which case we do cover it"
Has anybody else ever seen such a policy?
In which case they would pursue the the plumber's insurance.
Not rocket science is it? :rolleyes:
