Trianco coal boiler
28 Nov 2020
Nottinghamshire
I have a Trianco TRG45 gravity feed boiler. Its been working fine but now goes out regularly!!! It does not boost back up to full burning from slumber.
If the boiler has been on slumber due to the water being at temperature when a call for heat is made the burn will not boost up again.
A few shakes of the ash mover reveals glowing coal which it i put a few sticks will reignite the boiler to normal working.
The chimney and all flue including the second air feed have been cleaned. I use prebagged coal so even tried some older bags from a different delivery.
Any ideas what is the problem?
21 Feb 2020
Check all the moving parts and free them up may seem daft but coal works its way into every nook and cranny. Bob
19 Jul 2007
Have you cleaned the Fan and throat.
Is the heat leak rad working.
Check F E tank water level.
Check draught stab is not stuck open.
Are flue ways clear.??
Also make sure the fuel regulator plate has not dropped.
28 Nov 2020
Nottinghamshire
Hi all, thanks for the replies, boiler taken to bits to clean, including the secondary air vent at rear, fan removed and cleaned. Regulator plate got a jubilee clip on it to stop that moving. Heat leak is red hot when boiler working properly. Cleaned airway with soot breaker.
Burn was on its last legs this morning so after a few shakes of ash remover saw a glow of red burn. Put in a few sticks and up it boosts. Back to normal working.
Once it clicks off after reaching temperature it turns the fan off. This is the problem when the temperature drops and the fan kicks back in the fire will not build up to the required heat burn .
Just clean the throat flap because I noticed that it becomes tighter when the heat is on due to expansion. Fingers crossed.
Going through coal bags looking at different serial /batch number to try and rule out coal quality.
Watch this space!!!
28 Nov 2020
Nottinghamshire
Anthracite, grains.
This morning good news is the boiler working as normal. So I've put a bag of coal in from the batch that I was having problems with. If its out in morning it will point a finger at a bad load of coal.
19 Jul 2007
I would agree !!
BTW you are supposed to turn stat up and boost fire before De clinkering.
Tip. Before boosting fire, inspect the front of firebed from ashpit door to check for fuel bridging caused by incorrect fuel regulator setting.
28 Nov 2020
Nottinghamshire
When i have the problem in a morning the water is cold so I no their is a problem. When I get to the boiler the fan is running so I open ash pan door and its dead. Two shakes on declinker and you get the fire bed to the front but just glowing, its not boosting up at a full burn. Pop 2 sticks in and away it goes!!
Seems like the coal just needs a little help. Lol
19 Jul 2007
Reading through the thread I notice you mention bringing the firebed forward.
The correct firebed position is just in front of the secondary air duct below the flueways and fan throat.
The fuel should be completely burned before the front of the fire grate.
Try raising the fuel regulator plate to increase the flow.
What is the jubilee clip doing. ( Corroded peg in Hopper ) ???
Incidently what is your method of lighting it from cold ??
28 Nov 2020
Nottinghamshire
Jubilee clip is to stop the throat in place on the peg. It the past the plate as dropped, this makes sure this can't happen.
Fire lights and sticks to light , no problem. Been using this boiler over 5 years, just started getting problems. Can only put it down to a bad load of coal at this moment.
28 Nov 2020
Nottinghamshire
Sorted!!!! After reading all the helpful replies to my problem I thought I must be missing something but I had covered everything.
I decided to start again and found the fan had vibrated lose and come adrift so the airflow was not as should be. Put back in place and all seems good.
Thanks for all your help
19 Jul 2007
In post 4 You said that you had removed and cleaned fan.
You obviously didn't refit the fooker !!;)
