Trouble installing curtain brackets onto a batten
25 Apr 2011
I'm trying to install curtain brackets onto a batten that's already up above the window however, the screws don't go straight through. Should I
a) drill a hole further into the wall for the screws to go in or
b) drill a larger hole to insert a wall plug or
c) get shorter screws (will it support the brackets & rod?)
Many thanks
You don't say how thick the batten is but I would suggest you should have at least 1" of any screw into it. It is surprising how strong a short screw is when fixed into timber.
If your batten is thinner that 1" then I would recommend drilling through, just far enough so that you can insert a 6mm(red) or 7mm(brown) plug and use suitable length screws.
You could, as you say, use a 3mm masonry bit through the batten just deep enough to pilot the tip of the screw into the wall.
I presume the batten is solidly fixed.
The batten is about 1.5 cm - the screws 3 cm -well below an inch, if the timber is strong as you say, I'll just try shorter screws.
Thanks for the replies.
He was referring to misterhelpfulls post. 15mm will be fine, or last occupier would not have used it.
