Just a thought but my sister is having front room soundproofed so vertical battens then foam insulation in between followed by plasterboard on top then skimmed.
I've seen some special plasterboard fixings called Molly plugs which are metal plugs that expand outwards with a special tool. If I use around 8 of them would it be safe to hold a 46 inch led tv? I'm assuming here none of the screws will go into the timber as it will be difficult to know their position.
