Have done it many times, make sure you use the joint mesh tape and when plaster is dry, rub down hard with glass blocks on all joints then apply Easi-fill 45 over it then very very lightly rub it down with fine grade glass blocks, will be dusty because it's a very fine filler but it's a fantastic smooth finish and you won't notice at all
