Indeed they are!Ah, I think I understand - the two cable holes in the casing are designed so that you can have a LNE cable going in AND coming out - Doh!
As the fitting has an earth terminal, that would suggest the fittings require a circuit protective conductor (AKA earth, but not the correct term) and as we are no longer friends of the USA, the term ground must not be used.
