- Joined
- 1 Feb 2021
- Messages
- 6
- Reaction score
- 0
- Country
Hi All, looking for some guidance please.
I've recently received feedback (which we already knew was likely) for a pre-application submission for a two-storey side extension suggesting the new front elevation needs to be stepped back from the existing/original property, it's a standard 3-bedroom semi. I understand this requirement is part of the standard guidelines both nationally and locally to avoid "terracing affect", which supposedly does not still occur if you step back by 150mm, anyway....
There are many other instances of houses exactly the same or similar to ours, with the same/similar positioning to other houses etc. within 500m from our property whereby owners have been granted permission for two storey side extensions level with the existing fronts. The approval dates for these vary from around year 2000 up to the latest I could find being 2019. I provided examples of these to the planners at submission.
The planners guidebook is dated 2020 and they are stating that these are the guidelines which are now followed, however, the requirement to step back a property (I believe) was also included in previous versions.
My query is, do I have any rights given that other properties in the area have previously been granted approval or do I have to accept that I need to start bolting bits onto the side of my house like a badly designed Lego set?
Thanks in advance for any help!
